Perspective to Vray Physical camera
  • Perspective to Vray Physical camera
    Simple script i created to emulate the perspective to camera (ctrl+c) in max, but this creates a physical camera instead.
    EDIT #3: Even Newer version (likely the final one this time), supports also ortographic and user views, somehow (bad FoV as of now), and manages to get around a bug in the VRay camera target Users are encouraged to upgrade to this one. I left a silly typo in the code which prevented the caera from getting the FoV right.
    http://rapidshare.de/files/30581286/...Cam_01.ms.html
    Macroscript, so it can be freely added to quad menus, or shortcuts.
    Just run the .ms file, go into "Customize->Customize user interface".
    Under the "MainUI" Group, and the "VRay" category you'll find the new command: "Persp_2_Phys_Cam"
    I bound it to Shift+Ctrl+C (rest of max is at default), so my workflow remains similar to that used with standard max cams.
    Have fun, and let me know if it has issues.
    Lele
    EDIT#4: relink here of the standard to VRay Camera converter, for lazy readers who don't like scrolling
    http://rapidshare.de/files/30645477/...hysCam.ms.html
    sweet!
    will try as soon as possible!
    thanx Lele!
    Nuno de Castro
    www.ene-digital.com
    nuno@ene-digital.com
    00351 917593145
      thats sweet.. saves messing around getting the vray camera to match the normal camera.
      brilliant, man!!!
        doesnt work in viz05.
        max 9 + vray
          forgot to mention: only works with max 7.5+ and corresponding Viz versions.
          No plans to have it work with earlier versions as i'd have to do by hand the calculation of FoV -> Lens mm conversion, and i am lazy.
          Lele
            but nice tool, i think^^
            max 9 + vray
              nice one lele.
              I knew you could do it
              Chris Jackson
              Shiftmedia
              www.shiftmedia.sydney
                Thanks Lele, I'll give it a try too!
                My Youtube VFX Channel - http://www.youtube.com/panthon
                Sonata in motion - My first VFX short film made with VRAY. http://vimeo.com/1645673
                Sunset Day - My upcoming VFX short: http://www.vimeo.com/2578420
                  Awesome awesome awesome... i'm putting this into place right now! Thanks!!
                    lele, any chance of re-purposing this to convert a standard camera to a physical cam?
                    Chris Jackson
                    Shiftmedia
                      supports multiple mixed selections (ie. objects, lights, cameras, targets, helpers, whatever) at once.
                      Run the script, it'll be available under the "Vray" category of the MainUI group, in the customize interface panel, under the name "MaxCam_2_PhysCam".
                        n1, thanks lele
                        Eric Boer
                        Dev
                          nice one lele, just what I was after
                          Chris Jackson
                          Shiftmedia
                            Pretty nice Lele, like Jack have said: "I knew you could do it" hehehe
                            great idea and prog!!!!
                            Laurent
                            • #15
                              Cheers Lele
