Displacement and animation
Model the tiles, instance, and attach.
Yup - he's right, I've found in a lot of tests that although your viewports are slower because of the extra polygons, the render turns out faster. I didn't have too many problems using displacement and animation so I'm not sure what problems you're expecting but maybe for peace of mind you're better off modelling the little bits so you don't have to worry about getting render errors?
Re: Displacement and animation
Originally posted by cristoforoI remember hearing that using displacement with animations is not a good idea.....well.....I NEED to use it. I need to do an animation of the below seen.........displacement on the stone and roofs. What do I need to look out for? Are there special settings to use? Thanks.www.dpict3d.com - "That's a very nice rendering, Dave. I think you've improved a great deal." - HAL9000... At least I have one fan.
i thought that I had read something on this forum about displacement and animation.....good to hear though that it is not a problem. Maybe I should see the render time difference displacement and geometry. Though, it would sure be a pain to have to model all the roof tiles plus the tiles of the extra buildings I must still build! thanks for the replies!
I've had problems with using displacement in animation when the "view dependent" option was clicked on. It seems that as the camera moves the displacement is recalculated based on the view and on a large area you may see subtle shifts in value that seem to happen in triangular areas. I fixed this by turning off that option, but the render times doubled.
