Rendering selected
  • Rendering selected
    Why can't i render selected using Vray?
    I can render regions but i would really like to render selected for compositing in photoshop.
    If it isn't possible there a work around.
    Greg
    put all objects except the one you will render to matte object.
    Jonas
    www.jonas-balzer.de
    www.shack.de
      Render out the RenderID pass along with your normal render,then you have an easy way of selecting objects in PS that you maight want to tweak individually.
      hope it helps
      Peter
        The renderID is a good feature - but how do you get around lack of antialiasing?
        Jonas Andersen
        Cadpeople | Visual Communication
        www.cadpeople.com
          It is better to use the VRayWireColor element.
          nikki Candelero
          .:: FREE Your MINDs, LIVE Your IDEAS ::.
            You're right - wirecolor does antialiase, but still produces som uneven edges when you apply a 100% reflecting material (red box)
            Any reason?
            Jonas Andersen
            www.cadpeople.com
              Thanks folks,
              I've never used the render elements before but i'll have a look into it and if i can work it out.
              At first glance it seems pretty straight forward but i've thought that before so any tips helpful.
              What is the renderID feature? or where can i find it?
              Cheers
              Greg
                It's one of the vray render elements.
                  Any reason?
                  V-Ray always antialiases based on the RGB color channel. So, if there is no reason to put more samples in a given place (e.g. the RGB difference is too small), V-Ray will not bother to take more samples. This may show up in other render elements as artifacts, which should not prevent you from using those channels as normal.
                  If you want to reduce this effect, you can turn on the "Object edges" and "Normals" options for the Adaptive subdivision image sampler, which will force V-Ray to sample object edges at the maximum AA rate. This will slow down the rendering, but may produce render elements with clean edges.
                    Is that the 'Object Outline' option? - and what do you do on 1.5RC3 - can't see the 'Normals' checkbox.
                    Jonas Andersen
                    www.cadpeople.com
