Question: VirtualPC / VMWare to mix 64bit/32bit renderfarm
  • Question: VirtualPC / VMWare to mix 64bit/32bit renderfarm
    Would it be possible to let a XP 64 run 32 and 64bit
    backburner/max 9 configs with VirtualPC or VMWare (which
    are free) at the same time, allowing to render in a mixed
    renderfarm or would max not allow this kind of emulation?
    Thanks to the fast PCs of today there shouldn't be a
    big loss of speed....
    Thanks in advance,
    Robert
    robert we run xp64 with render jobs from 32bit max 8 and 64bit max 9 and everything works as it should
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      But I think he wants to be able to run jobs from both 64bit and 32bit Max 9?
        Yes, that's what I wanted to know, if it's possible to run
        64bit and 32bit Max 9 jobs on the same 64 Bit machine.
          64bit max 9 will render exactly the same as 32bit max 9, so why would you want to have both installed?
          Chris Jackson
          Shiftmedia
            Because if you submit a render job from a Max9 64bit workstation, only Max9 64bit nodes will render it. Likewise, if you submit from a Max9 32bit workstation, only Max9 32bit nodes will render.
            So depending on your renderfarm/workstation setup, you'd conceivably have to submit your job twice to ensure the entire farm is working on it.
              ah wasnt aware of that...... thats a big problem for autodesk to fix
              Chris Jackson
              Shiftmedia
