Vray Spawner - x64 MAX 9 - not loading scene
  • Vray Spawner - x64 MAX 9 - not loading scene
    When I try to start the Vray Spawner for the 64bit version of Vray, running on Windows XP 64 for MAX 9 64, it won't load the vraydummy(xx).max file.
    It keeps trying to but instantly closes, over and over again.
    On the same machine, the Max 8 Vray Spawner loads absolutly fine.
    What could it be?......
    --||atomcraft||--
    www.chrisglew.com
    | Sun Ultra 40 Workstation | XP 64 | 2X Dual Core Opteron64 280 | 8GB RAM | NVIDIA Quadro 4000 |
    is the render machine able to "see" a license?
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      Found it - it was my fault, a dodgy install of MAX 9
      Just a tip - don't install MAX 9 off the .msi files like you did with MAX 8!
      EDIT___
      However It is still not working and doing the same thing! How strange - the spawner on my local machine works fine....
      --||atomcraft||--
      www.chrisglew.com
        Hi atom,
        Try running backburner manager and spawner once, on the machine with
        the problem, this should fix it.
        I had exactly the same problem, and did this and it worked ok after that.
        steve
          good tip there steve! i have finally been able to get DR going on my laptop!
          Chris Jackson
          Shiftmedia
            I think you may be onto something there - however, I can't even get backburner to work - I can't uninstall it as it has an error and I can't install the new version until the old one is removed! So frustrating!
            Has anyone else encourtered this?
            --||atomcraft||--
            www.chrisglew.com
