enable hyperthreading on DR machine
  • enable hyperthreading on DR machine
    I'm using VRay DR on a computer that has hyper-threading, but the hyper-threading is not being utilized. Is there a way to activate hyper-threading on a DR system?
    HT is usually set up in the bios. its not something that DR should be turning off or anything like that.
      SEE WORK AROUND THIRD REPLY DOWN
        i think displacement has a problem with multiprocessors...i cant remember
          If you have MAX9 you must write something into max listener window to tell max about using more than 1 CPU (virtual or physical)
          search here for MAX9 and Vray licence issue
            The work around is detailed on page 2 of this thread:
            http://www.chaosgroup.com/forum/phpB...r=asc&start=25
            tryharder wrote:
            How can I use the MaxScript property. Thanks for some deeper step by step explanation.
            Vlado wrote:
            make V-Ray the current renderer, open the MaxScript listener (F11), type "renderers.current.system_numThreads=2" without the quotes and press Enter.
            Thanks neoVisual
