Intel Quad Core
  • Intel Quad Core
    Does anyone have a Quad COre system and can upload some benches......
    I am gonna get another Slave and am thinking about upgrading to 64....8GB Ram....etc.....and Monarch seems to be down or under construction....
    Thanx all
    Eric
    Eric Camper
    Studio 3D
    www.dbfinc.com/studio3d
    http://www.chaosgroup.com/forum/phpB...r=asc&start=25
    look at the bottom, at jujubee's post :
    the Intel Quad QX6700 clocked in this benchmark around 3:14.
    It was wrongly compared it with a dual xeon 5160 system, which has the xeons running at 3ghz, where as the QX6700 is running at 2.66ghz.
    If you realy want to compare rendertimes you should compare between the QX6700 and a dual Xeon5150 set up.
    I very much wanted to buy me a QX6700 but they are damn hard to get at the moment...
    - Geert -
    www.3DIGIT.be
    3Dprinting in full color !
      Well, if you can hold off till the new year, I'm getting a new dual-quad core 2.33 ghz system here at work but I'm out until Jan 2nd, I'll probably bench it the first day and post it here somewhere.
        It wasn't 'wrongly' compared - it's compared to what is posted in that thread and simply looking at what is the fastest out there. And yes, the clock speeds (Mhz) are different. But if you want to level Mhz out, then the QX6700 is probably on level with 5150s.
        When I look at these benchmarks, my primary focus is to see which has the fastest speed as well as which processors have the most reasonable price-tag.
        LunarStudio Architectural Renderings
        HDRSource HDR & sIBL Libraries
        Lunarlog - LunarStudio and HDRSource Blog
          sorry to have put it in such a crude way, jujubee...
          But it is unfair to make it appear that Xeons beat the QX6700 quad core by 40s, if you don't mention they are not running at the same speed.
          It gives people with little technical insight a false impression.
          I'd love to see some 5150 xeon results here on this board. From crude extrapolation, i'd say the xeon 5150 and QX6700 are matched very closely, except for the price then...
          Which leads to the conclusion that, if you want to go for xeons, you absolutly need to go for the quad core versions (5300 series), because the QX6700 is apparently a much better "bang for da buck". It is cheaper then the 2 xeons combined, it can be used on a cheaper MB and uses cheaper memory.
          - Geert -
          www.3DIGIT.be
            Do you really think that it makes sense to buy dual quads? As far as i understand, they're going to multiply the number of the cores with each new generation, and since dual sockets are so expensive in terms of more expensive cpu, mobos, and RAM, it seems to me that it doesn't make much sense.
            The loss when using dual quad cores is substantial, you get a 50-60% increase with the second cpu, and the price is much higher than that.
            Dusan Bosnjak
            http://www.dusanbosnjak.com/
              Well, if you really want to get technically matched, mHz eve across brands don't match. As I said before, the thread is not a mHz matching competition, but a rendering time comparison.
              When the quads came out, people (including myself) thought it would be the fastest but so far, the 5160s still beat it. I don't see why that is confusing...
                It's not so much confusing as it is just not very logical. Too add some logic, the 5160's cost about $900 apiece so $1800 for 4 cores. Two 5150's (a performance match to the qx) are still $1400. The qx can be had for under $1100. In price per performance there is nothing else available that beats the qx...
                Eric Boer
                Dev
                  And what about the expensive motherboards, RAM, power supplies...
                  Dusan Bosnjak
                    ReRender is right from what I've seen - price-wise the QX home-built systems can be cheaper than dual 5150s or 5160s.
                      Good point, the xeon boards are about $500 where as the 965's are $200, the qx does not need a particularly large PSU unless you are running sli too, 500 watt should do, the xeons need about 850. For memory the xeons use ECC Ram so you'll pay a premium there too. All making the qx an even better value.
                      Eric Boer
                      Dev
                        Where did that come from? That seems unreasonably high. The woodcrest xeons are supposed to consume less power than the opterons and I am running a dual opteron on a 400w ps without a problem. Granted, it is a rackmount computer with no video card and one hard drive, but still. I just ordered a couple of these from supermicro http://supermicro.com/products/syste...S-6015V-MR.cfm
                        They come with a 520w supply and I doubt they would really underpower their own systems, or even cut it close.
                        Tim Nelson
                        timnelson3d.com
                          Yeah, a blade is going to require less power since there is no video card and smaller fans, etc. Looking at supermicro's desktop stuff they recommend a minimum of 550 -700 watts watts for their workstation boards. I have been looking at the Tyan's which seem to require a bit more power or maybe they just spec a bit more overhead. Don't get me wrong, the xeons are great, I have a Dell 5150 at work and it is a great system, just pointing out the value of the qx.
                          a little ot, found this PSU calculator http://extreme.outervision.com/psucalculator.jsp
                          Eric Boer
                          Dev
                            Yeah it's still a great value for time/price comparison. Personally speaking, I think I've been spoiled with sub-$300 x2 processors. I hope the QX drops in price within the coming months.
                            As for PSU, the Apple Pros with the dual 5160s come with a PSU which I believe is under 400 watts. I looked this up because I was considering putting in a 8800GTX which has steep power requirements.
                            • #15
                              Besides having to be powerful, are power supplies for xeon based computers supposed to have a different standard? EPS12v or something, does that add to the cost?
                              Dusan Bosnjak
