Anisotropic ?!!! How to get this result...
  • Anisotropic ?!!! How to get this result...
    Hello,
    I'm just wondering how to get this result with vray :
    http://www.xsi-blog.com/archives/197
    Is-it even possible with Vray ?
    I think it's the solution of this thread :
    http://www.chaosgroup.com/forum/phpB...ht=anisotropic
    Please help !!!
    I need to build those kind of shaders, and some carbon fiber for industrial visualisation and luxury watches viz :
    http://img254.imageshack.us/img254/4749/cdplayer9nm.jpg
    It'll be great if someone succed building a shader like that...
    Best regards...
    My Flickr
    very interesting thread !!! I'm also very curious about that!
    Laurent
      at the moment you can only use the uv channels for this.
      Try this:
      Use a Bend modifier on a Plane to generate a Disc and then set the UV derivation to UV. This way you get a circular UV vextors derivation.
      Implementing a map for the UV derivation should be doable. We should add it to the wishlist
      Dieter
      visit my developer blog
        If i understand your point dimo, it's not possible to have this kind of shader into vray ?!
        Vlado... could you please add a map to vector derivation... Pleeeaaaasssseeeee...........
        Best regards...
        My Flickr
          http://3dcenter.ru/forum/index.php?s...sotropic&st=90
          try to read this old link and is helpful
          bye
          Workstation: Asus p9x79WS I7 3930K Noctua NH-D14@4200GHz SE2011 16GB RAM Kingston Hyperx Beast SSD 500Gb Samsung x2 SATA3 WD raid edition4 64MB GTX760 2GB DDR5 CoolerMaster 690III
          https://www.facebook.com/essetreddi..../photos_albums
            Originally posted by pengo
            http://3dcenter.ru/forum/index.php?showtopic=16995&hl=anisotropic&st=90
            bye
            Very interesting but with this technic you can't go as far as the mental ray shader...
            You can't render this correctly :
            The specular change over the animation like in "reality"
            Sorry my english sucks...
            Best regards...
            My Flickr
              Yes, you can't do this at the moment with vray the way the xsi shader does it. You can only try to create a model that has the uv the way you need it. But looking at you reference picture this would be very hard.
              You should post to the wishlist.
              The vrayshader is almost there. The only thing it does not do right now is to sample a bitmap at the uv coords to get a vector instead it takes the uv as the vector. I bet this could be implemented easily.
              Dieter
                Originally posted by dimo
                Dieter
                You can but... it will be very hard to get a model that does the correct specular...
                I had my request to the wishlist :
                http://www.chaosgroup.com/forum/phpB...ic.php?t=18837
                My Flickr
                  You mean I can't do this in Vray?
                  "Why can't I build a dirigible with my mind?"
                    nice one clifton, now do it on a surface like the centre consol of that car
                    Chris Jackson
                    Shiftmedia
                    www.shiftmedia.sydney
                      I mean you can't to this on a single plane in vray... or I don't know the way...
                      Best regards...
                      My Flickr
                        uh, I don't have time right now. The "correct" way to do what you're asking would be to take the top faces off my chamfered cylinders, create a more extensive array, and conform them to the shape of the dash (console). Or, the quick way would be to array a bunch more of the cylinders, render, and use as an image map on the console.
                          i am ashamed to say this but maxwells implementation of this type of shader is quite nice
                          Chris Jackson
                          Shiftmedia
                            @stilgarna:
                            yeah, the trick is the geometry. I've always found chamfered cylinders with a minimal chamfer work well. The material is just a basic vray stainless (black diffuse, white reflect w/fresnel unlocked at 8 IOR and 0.6 glossiness w/24 subdivs. Anisotropy at -0.6 and a radially blurred noise map for the "brushed" look. I forgot to make it Ward though...).
                            • #15
                              yes the cylinder work like a bended plane, but it would really be easier if you could just use a map for this instead of remodeling.
                              Dieter
