VRay Light Monkey V. 0.3
  • VRay Light Monkey V. 0.3
    It's a really simple tool to mass change VRay Lights.
    It's not yet finished, as i'm looking for a clever way to implement the big buttons' functions (at the bottom), which currently don't work.
    Also, the dome texture button doesn't currently support drag and drop, due to the object inherent limitation when used in this context.
    A rightmouse Click, though, will clear the map from the slot.
    It's a beta, in that there's no installer, no support given, but i will hear comments and requests.
    It's meant to work along with any present tool to change vray lights (lightlister).
    Maxscript->run and point to the mse file.
    Edit: maybe you'd like the URL to download the actual tool too...
    http://www.scriptspot.com/lele/lightMonkey_0.3.mse
    Edit #2: now it all seems to work. grab v. o.3 from the link above.
    When using a VRay hdri map as domelight texture, saving the defaults will attempt to bring it back once the preset is reloaded, with the same map name, and settings.
    Since i often use kitchen.hdr from Paul Debevec, i really wanted this to be possible.
    Lele
    Hey Lele, you're THE MASTER
    Lighting & Rendering Supervisor
    Marulli Studio
      yeah, yeah, Simo.
      Still waiting for that beer though, master or no master
      Lele
        nicee!
        Nuno de Castro
        www.ene-digital.com
        nuno@ene-digital.com
        00351 917593145
          Really like the layout of the ui!
            Originally posted by studioDIM
            yeah, yeah, Simo.
            Lele
            You know as fast as we can
            Marulli Studio
              Lol, yeah.
              We'll have crouches and long, wispy beards by then, from the look of it :P
              Updated to version 0.3
              It all works.
              When using a VRayHDRI map for a dome texture, the script will save in the defaults all of the map data, and bring them back exactly as they were.
              Ideal to setup an IBL with two clicks.
              Undo is supported via the Max interface.
              For those with RCs without the new "system lighting units" option, don't worry, it will not do a thing in case, and just carry on applying the other properties.
              The coloured bar to the right is an easy "dragMe!" area.
              As the interface is really long, if you're with a low resolution it should make it a breeze do drag around and reach the whole menu.
              Lele
                You're just trying to one-up my light lister aren't you?
                  Ziiing!
                  I never use the lightlister, personally.
                  Not yours, not the standard one.
                  I find it clumsy as a concept, and always preferred nice, one button solutions to anything.
                  Better still if the buttons are BIG
                  In any case, i guess it's a nice addition to those which DO use the Lightlister, as this is a selct /click, select/click solution.
                  Plus its interface is a simple, identically placed, rip of that of the vraylight itself.
                  So no figuring out, just run and use.
                  Lele
                    now now. i can see why you said your neuron traffic is hectic.
                    many thanks, LELE. lots of it...no beer though
                    Dominique Laksmana
                      well, thanks again for sharing your work with us. I must admit I don't use lightlisters much, but I guess it'll happen more often, like, from now on
                        yeah, yeah, Simo.
                        Lele
                        Too much beer for you man, wonder if you can handle it
                        Thank you for this tool!
                          Lele, I'm using max 8 and vray 1.5 RC3. This is what I'm getting when I load the script.
                          I use the light lister quite a bit and your tool looks really helpful. Thanks.
                            Mmmh, i might have encrypted it in max9 sp2.
                            Bad, bad Autodesk.
                            Will upload a working version soon, hopefully (monday...)
                            Lele
                            • #15
                              Updated.
                              It works with max 8 now.
                              Lele
