Hi people,
Can you take a look at this screengrab and tell me if this is correct. I have 3 vray lights at the window setup as skylight portals (the reason for doing this was I saw the new features for MR in max 2008 and saw that the guy put the skylight portal up at the window to direct all the rays into the room).
I also have a vray sun and environment pointing down into the room.
Is this the correct way to setup a scene like this ?
I seem to lose shadow definition on some objects in the scene and they almost appear to float, but im not sure how to overcome that.
Also, any suggestions on how to improve the mood of the scene would be good.
One more thing..sorry
I guess when using the vray physical cam and such high multiplier settings for the sun, the only way to correctly expose the outside would be to set the camera up at a lower exposure...as you would a normal camera ..is this correct ?
Any help is appreciated.
Thanks
Steve
[/img]
Thanks
Steve
