Machine almost unresponsive when rendering locally
  • Machine almost unresponsive when rendering locally
    This is mainly an observation of the performance of our workstations and I wonder if anybody else has the same thing.
    When working on *reasonably complicated* scenes, we have noticed that our *reasonably powerful* machines become very unresponsive when rendering locally, yet if we render the same scene using DR, the machine can still be used for other tasks - email/surfing/even a bit of AutoCAD modelling or Photoshop work.
    The spec of the machines is as follows:
    Intel D975XBX2
    Dual Intel Core2 Quad CPU @ 2.66GHz
    4GB RAM (800MHz DDR2 Synchronus)
    XP 64bit
    Vray 1.50.00 (32bit)
    Max 8 (32bit) with latest service packs etc
    Now I don't really know why this is the case - I know that Vray and Max are obviously going to use a good portion of the systems resources (CPU and RAM) when rendering, but I am (almost) sure that with older machines/versions of software, we could certainly multi-task when rendering. With these newer machines we struggle even to check email when a local render is under way - the machine basically locks up until the render is complete - even clicking 'cancel' is difficult!. Yes, I could go into task manager and free up one of the processors for email/surfing etc, but we never needed to do that yesteryear. What makes it stranger still is that when we do the rendering as a DR (most often the case these days due to the ever-increasing complexity of our projects) multi-tasking is a breeze.
    Is this a common issue?
    Kind Regards,
    Richard Birket
    http://www.blinkimage.com
    set max.exe's priority to below normal. this makes it a lot more responsive imo for some surfing in the background.
    WerT
    www.dvstudios.com.au
      http://www.chaosgroup.com/forum/phpB...901&highlight=
      :P
        the easiest thing to do would be to start max from a batch file with the following command:
        start /belownormal 3dsmax.exe
        this will auto set low priority.
        Dmitry Vinnik
        Silhouette Images Inc.
        ShowReel:
          wow! just read that other post - i have continued the debate on that thread...
          Kind Regards,
          Richard Birket
