strange distribution?
  • strange distribution?
    Hi!
    I was just wondering why I get "clusters" of samples on a smooth one color surface, why isn't there an even distribution of samples. Is there some setting that is wrong or is this normal?
    se pic. http://www.svenskdesignab.se/samples.jpg
    Regards
    /Tobias
    probably because u calc that irmap in DR mode...?
    Nuno de Castro
    www.ene-digital.com
    nuno@ene-digital.com
    00351 917593145
      Oh, so thats what makes it look strange, will this make the final image look bad in comparison with a non DR render?
      /Tobias
        i am not sure, but i ve retained the idea that calculating irmap and Lc localy would always be safe-proof.
        but now that u are at it maybe u could run a quick test?
        Nuno de Castro
        www.ene-digital.com
        00351 917593145
          Yep, I will do some testing tomorrow on a smaller image, this one is over 4100 pixels wide.
          /Tobias
            Nuno de Castro
            www.ene-digital.com
            00351 917593145
              Also, you will get such "clumping" if your hemispheric subdivs are too low and your color threshold for the irradiance map is too low.
              In that case, the samples will be noisy and with a lot of variation, and the irradiance map engine will think that there is a shadow there which needs to be sampled more.
              A solution would be to either increase the color threshold, or to make the irradiance map samples less noisy (by increasing the hemispheric subdivs, or decreasing the DMC noise threshold, or both).
                Thanks!
                feels like my head is spinning from all this increasing and decreasing
