Hi all,
I have only recently started to use LC for secondary, and I am confused how to best work out if the size of the samples and quantity is good enough? With IR as primary it is easyier to see if things are splotchy or not refined enough, and you can make changes to suit. But with LC some times I increase a settings and see no effect. Is there a good way, ie to start with LC for both 1st and 2nd and get a rough setup? Then move to IR and know the LC is ok, and any problems are due to the IR setting?
I realise this might sound a bit noobish but LC does seem to be a bit of a dark art!
Thanks
Thanks
