Roughness Curiosity
  • Roughness Curiosity
    Apart from a measure of one's hangover, can anyone explain what the roughness parameter of the vraymaterial does?
    I have read the manual (quoted below), and looked at the teapot examples but I'm still not quite sure when I would use it...
    "Rougness - this parameter can be used to simulate rough surfaces or surfaces covered with dust (for example, skin, or the surface of the Moon). "
    Anyone have any good examples of it in action, or good tips on what types of materials its useful for?
    www.peterguthrie.net
    www.peterguthrie.net/blog/
    www.pg-skies.net/
    I second that.
    It's not very clear for me too...
    Gael
      I think this is pretty obvious. You can use it for rough surfaces. For example a clay pot. IF you're familiar with the old max oren-nayar shader's roughness parameter, it's pretty much the same I think.
      By the way, when I saw it, first, I thought it was a global control for shader roughness affecting the glossiness of everything. Which also would be quite evident imo.
      best regards,
      A.
      credit for avatar goes here
        And somewhat more usefull imo!
        Nuno de Castro
        www.ene-digital.com
        nuno@ene-digital.com
        00351 917593145
          Yes, I suppose if we would wanted to stick to a more realistic shader model, a global "roughness" parameter would be the rational choice, but than, I think people would just want to have separated control back.
          best regards,
          A.
            yep...thought so as soon as i pressed submit reply!
            Nuno de Castro
            www.ene-digital.com
            00351 917593145
              thanks for the reply Aldaryn. So other practical uses for this would be white plaster walls, concrete, rubber etc?
              www.pg-skies.net/
                haven't really used it myself, but here's a comparison of how the same three teapots would look in one way and the other:
                  Ive used it to nice effect on a lunar surface.
                  Made the surface loose the CG look and really start to look dusty.
                    Is there any performance hit usinng roughness?
                    Patrick Macdonald
                    Lighting TD : http://reformstudios.com Developer of "Mission Control", the spreadsheet editor for 3ds Max http://reformstudios.com/mission-control-for-3ds-max/
                      I know this is quite an old thread, but are many people using this 'roughness' control? I was wondering how it scales to a scene?
                      Kind Regards,
                      Richard Birket
                      http://www.blinkimage.com
                        An old thread again, but there still doesn't seem to be an answer.
                          It has no relation to the scene scale; it just controls the way the surface reflects (direct) light.
