Maxscript Vray What does it all mean?
  • #16
    Recursion is one of the fundamental concepts of programming, so nothing dangerous there You just have to be careful to have a terminating condition when the recursion must stop.
    For the forum messages formatting, you can use tags enclosed in brackets, like [ b ] some text [ /b ] for bold, [ code ] and [ /code ] for a block of code etc. There should not be intervals inside the brackets, I just added them so that you can see the codes.
    • #17
      Couldn't help but have a genuine laugh at this.
      I DO know something about recursion, and also know something about MISSING terminating conditions too.
      Lele
      emanuele.lecchi@chaos.com
      Disclaimer:
      • #18
        There's always task manager...
        Eric Boer
        Dev
        • #19
          thanks for that format help Vlado, I also discovered by accident that if you click on the [IMG] button at the bottom it gives you a list of the VBcode legal to use.
          So here is another attempt at posting the code in a formatted and "READABLE" fashion
          Code:
          collect from a series of nested mix maps specific values and write them to a text file
          global indxmk = 1 --index counter for the 1st dimension of a 2d array used below = p
          fn CollectMIXValues t =
          	if t != undefined do
          		if (classof t == BitmapTexture) then
          				-- set the bitmap file name here
          				-- bitmap is not needed as that is set later with another function
          				) else if (classof t == Mix) do
          					-- make array (p) with values at each level
          					p[indxmk]= #(t.color2 , t.mask.output.output_amount , t.mask.filename, t.name)
          					indxmk += 1 --iterate
          					setFile t.map1 -- recurse into the mix map by parseing the current map, submap 1 of it
          CollectMIXValues (meditmaterials[11])
          print p
          I discovered, to my horror, that file reading and writing isn't quite as simple as I thought it was going to be.
          And as for endless loops - there's always the power button and the door to the outside world...it exists! apparently.
          Raj
