Downloading now.
Sp2 is up on the site!
great new!. And now... come to play!
Thank's
cecofuliLast edited by cecofuli; 19-04-2008, 02:01 PM.
Hi
i have a question: why there isn't a history tool in the SP2? It's hidden?
thank's
cecofuli
normaly you read the readme.rtf file after installing
V-Ray 1.5 Service Pack 2 for 3ds Max readme
New features
Compatibility
·Compatibility with 3ds Max 2009;
·Support for the Lighting Analysis Overlay render effect in 3ds Max 2009;
·V-Ray specific Defaults switcher for 3ds Max;
VRayProxy
·Support for animated deforming VRayProxy objects;
Lights
·VRayLights in rectangle mode can now be texture-mapped;
·Texture-mapped dome lights use better sampling and have faster preparation phase;
·VRayIES light specifically optimized for rendering with V-Ray;
Render to texture
·HDR output for texture-baked render elements;
·VRay_SelfIlluminationMap texture baking element;
·VRay_BumpNormalsMap texture baking element to extract bump-mapped normals;
Render elements
·VRay_ExtraTex render element to store the result from the calculation of any extra texture map on shaded surfaces without the need to actually apply the map in their materials (can be used with VRayDirt for AO pass, or with Vertex Color map for UVW channels pass, or with Falloff map for custom z-depth pass or top/bottom etc);
·VRay_SampleRate render element to show the image sampling rate;
·VRay_BumpNormals render element and VRayBumpNormalsMap bake render element to extract bump-mapped normals;
·VRay_Illuminance render element for displaying the illuminance in the scene in physical units;
Shadows
·VRayShadowMap shadow generator that works with all V-Ray geometry objects (proxies, displacement, fur etc);
Materials
·VRaySimbiontMtl material specifically optimized for rendering procedural DarkTree shaders (requires installation of either DarkTree or SimbiontMAX from http://www.darksim.com);
With surprise, i believe that the History tool isn't hidden in this version. I use it a lot and works very well
And the illuminance elements. How works? I made some test, with VRayIES light and VRayPhyCamera. All work very well too, but the illuminance is in B/W and is very bright.
bye
cecofuliLast edited by cecofuli; 19-04-2008, 02:53 PM.
Originally posted by cecofuli View PostWith surprise, i believe that the History tool isn't hidden in this version. I use it a lot and works very well
You only need to have a system variable VRAY_VFB_HISTORY set to 1, once, to have it visible for every version that has it.
Hats off to the Simbiont addon, and to the IES lights Vlado.
Both are very quick and predictable.
Also, i love the sample rate render channel, it's a big aid to see how things are being sampled, which for this version of the DMC sampler is most intelligently and cleanly.
Finally, lowering dmc noise threshold, and raising max subdivs cleans up the picture to no noise at all.
Superb.Lele
emanuele.lecchi@chaos.com
Disclaimer:
Ehhh... i know lele and i use every day. But i have no crash, no bug with history and i don't know why this tool is in SP2 hidden.
