But i have no crash, no bug with history and i don't know why this tool is in SP2 hidden.
Unfortunately, I get a crash when I try to load the images.
Other than that, the VRayIES is working very well, much faster than the standard max photometric. The dark tree materials look interesting, I have to try them out some more. Has the noise threshold changed? I have to test some more, but using the same settings I was using before the render seems to take longer, but now lower settings produce less noise too, so maybe that is the difference.
Hmm... can someone explain what the "hidden" history feature is?
it allows you to save and load images (in vray image format with all channels if any is selected), from and to vfb. as lele says you just need to add a system variable to have it enabled.
"Quote:
Originally Posted by instinct
It's there just not activated by default. Create an environemt variable (for windows, not max or vray) with the name VRAY_VFB_HISTORY and set the value to 1...then you get an additional icon in the VFB on the bottom
just to ask, i guess the vrayIES is optimez for the vrayrender core. that should mean it's a bit faster then the default ies tool in max?
i should give it a test. hmmnm
