Hi there,
This might have been discussed a few times, which i almost all read, oh and for those yes i used the "search button." When rendering out an image i use the exr format, set the compression to none, standard options to Float - 32bit per channel, RGB ticked and no alpha. The alpha is rendered out as an element being a png file as 16 bit grayscale. The background is white and the object is black. In Fusion i add a black background, use a ChannelBoolean with Luminance BG set. And i do get a white line around my black object. I am able to remove this "aura" with a MattControl but thats actually not what i wanna do. My first though and still is that i am doing something wrong in vray.For IS i use A DMC as well as AA with Area(tried a few ) Min and Max in the A DMC IS is set to 4 as well the threshold is set to 0,01. Colormapping is set to Linear Multiply. This is, where i believe, the bug is sitting, not sure though. Using Vray SP2 and max2008. If you need any more information,files let me know
Thx in advance
Ralf
Thx in advance
Ralf
