Mixed map
  • Mixed map
    I am playing with a mix maps using a mask. My question is can I have a displacement modifier applied to just one of the mix map materials? I have material 1 with a grass texture, material 2 has a dirt texture, and I am using smoke as my mask. I have a displacement map on the object, but it is applying the displacement to everything.... is this possible ?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
    You'll need to create a slightly different mix map for the displacement, just replace the texture you do not want to displace with solid black.
    Eric Boer
    Dev
      Will that work with 2D displacement or just 3D?
        Both, but 2d can only use one mapping channel.
        Eric Boer
        Dev
          Yes the single map channel limitation has been a crux for me.
          "A severed foot would make the ultimate stocking stuffer"
          -Mitch Hedberg
            Hrmm.. I'm having a hell of a time trying to get this to work using 2D displacement. It's not bad on a small scale, using 3D displacement, but using it on an entire site will be painful. I'm using a GradientEdge texture to mix the texture maps and to fade the displacement map to black on the grass.
              mix
              I like what you are doing. I would love to see your material setting for that. Can you share?
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                Yea, thats looking really nice.
                I too would like to see your material setup.
                Many Thanks
                Patrick
                  MIX maps
                  I just wanted to bump this up so it stays alive. Up here in upper Minnesota we have a mix between grass and sand. I need to learn how to have a mixed material of grass and sand, just displacing the grass. I have tried a lot, but can't seem to get the look. Does anybody have any ideas?
                  This post so far has gotten be close, but nothing yet.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    No problem. I normally create various masks in Photoshop; using the various terrain meshes or CAD file as a template. I came across the GradientEdge texture last week here and it certainly simplifies things; many great scripts/materials. I also noticed the ReplaceColor mask material, but I haven't had a chance to play with it yet. Anyways, this was done on a simple plane with the path cut out with a shapemerge. Here are the material settings:
                    Mat 1: Grass to dirt
                    Mat 2: Dirt to concrete
                    Mat 3: Displacement Mat
                    I set the gradient on this map to 2' so the dirt wouldn't displace too much and the grass would displace more the farther from the path.
                    Mat 4: Vray Displacement
                    I'd love to get this working with 2D displacement, but I'm having a hard time getting around the one mapping channel limitation.
                    Edit: Sorry for the late response; I wasn't around much over the weekend to check the forums.
                      Try vertex paint and paint a mask. The main limitation with it is the need for a dense mesh but it is a very intuitive way to work.
                        Here's another on a small site just using a texture; a displacement mask created in Photoshop mapped/repeated along a lofted shoreline.
                          Yeah.. I'd love to be able to use vertex paint, but on a large site it's just too much. If I need more variation with a mask I'll paint it in Photoshop and save it out as a grayscale PNG; very small filesize.
                            Mix
                            I like, I like a lot. I am testing out now.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #15
                              gradient
                              How are you assigning the gradient edge to the elements? I don't see a way to use material id's so I am assuming you are detaching one your merged shape.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
