Render elements - atmosphere
  • Render elements - atmosphere
    Hi guys, few Qs
    1.What does vray_atmosphere do? Also, where can I see more about them? Other than that table, it's not very informative.
    2. How come vray_zdepth is not filtered? The aliasing is usually noticeable when I post process in PS.
    Also, can I add/view some of the elements if I forgot to add them to render before it began?
    Thx
    www.hrvojedesign.com
    For every render element, there is a checkbox, "Enable filtering"
    The VRayAtmosphere render element contains atmospheric effects like Fog/VolumeFog/VRayToon etc.
    You can only see render elements that were present when the rendering started. Otherwise V-Ray does not keep the information about them.
      Thanks for sucha informative answer. I'll check everything out.
        Oh, how come zdepth cannot "see through" glass? Or should I enable something?
        Also, you mean 3D Studios fog/volumeFog?
          Render elements cannot see through refraction or reflection currently... (but some may work with plain transparency).
          About the atmospherics - yes, the standard Fog and Volume Fog atmospheric effects.
