Plugin.ini Problems
  • Plugin.ini Problems
    This has been happening for some time now:
    Users (and myself) have been opening Max only to find the Vray plugin missing (unloaded). I open the plugin.ini to find that the lines contain the Vray reference is missing. I reinstall Vray and it recreates the ini with the Vray entries and it works fine.....for a while...then it happens again...over and over.
    Ive come to write a .bat file thats included in our login that overwrites it each time they login (or I can run manually) and I have made the file read only for some. Making it read only seems to work but making that change on 100+ machines is difficult and awkward with tight user permissions.
    Any idea why this happens? I was hoping it would go away with 2009 but it hasn't.
    -T
    I'd recommend getting rid of user profiles useUserProfiles=0
    No way to avoid needing to fix each box that I can think of.
    Eric Boer
    Dev
      Thanks (Eric?)! Did that along time ago. I suppose I will have to find a way to make the plugin.ini read only on all machines but it wont be easy..very much wondering the cause..
        you can start 3dsmax using commandline loading a user defined pluin.ini
        dont have the exact command in mind but something like
        3dsmax.exe -c //192../plugin.ini should be the command
        ask F1 from max about 3dsmax.exe
        __________________________________
        - moste powerfull Render farm in world -
        RebusFarm --> 1450 nodes ! --> 2.900 CPU !! --> 20.000 cores !!!
        just 2,9 to 1.2 cent per GHZ hour --> www.rebusfarm.net
          Without testing this - would the vray DR exe support this? Does it internally call 3dsmax.exe? Could you add these commands to the vray DR exe?
            Internally it starts 3dsmax.exe, yes. I will see if this can be added as an option.
