Fog or refract?
  • Fog or refract?
    I searched this but gave up wading through the 500 hits on the forum....
    I'm working out some kinks in a job material - making beer bottle glass actually - and I can't figure out whether to use make a brown glass with fog color and fog multiplier only, or with some refraction color, or with both? I am not clear why we have both (an attenuation distance and a colour is all we need for reality IMO). Could someone let me know which way and maybe why?
    I can hit something that looks not bad about 6 different ways, but I want the most realistic/accurate approach so it works more intuitively with lighting etc.
    Thanks in advance,
    b
    Brett Simms
    www.heavyartillery.com
    e: brett@heavyartillery.com
    Bumping the thread. I am still hoping for some guidance on this one but also have another problem/question to ask about: I am finding that with tinted/dark glass of any kind that the light falloff/absorption is really hard to control. See the attached thumbnails to see what I mean.
    In one I have the backlight set at intensity of 5, in the 2nd at 500, and the 3rd at 5000. The 4th image shows the material settings. GI is BF and
    No matter what I do, or how bright the light goes, I just cannot get much light through those bottles once they start to stack up. Even single layers of that glass material does not brighten up in a way that makes sense to me. At 100 or 1000X the light the single layers of brown glass should be blown out totally IMO.
    I have the material's cutoff at 0 and the reflect/refract at 50 each (not limited in the render dialog either). I have tested it with many variations of refract and fog colours/values and this is as good as I can get it. It just does not behave in a realistic way, at least to me. (I am using single bounce of BF GI in this example, and both types of GI caustics are turned on. Adding secondary bounces did not make a noticeable difference in the image)
    Is there something I am doing wrong with the material, or is this just how Vray works with transparency?
    I have to say that the Maxwell/Fry approach with attentuation distance and a refract colour is far easier to work with, and seems to behave much more realistically.
    Can anyone offer some help/guidance on this one?
    Thanks!
    b
    Brett Simms
      Another material variant with simple refraction colour variation - somewhat better but basically same thing.
      b
      Brett Simms
        I'd just go with refraction colour - it's a tint, not the quality or fake-thickness of the glass that you're affecting.
          I did try working with just the refract colour, but I'm trying to get something that looks more realistic and the refract colour just wasn't doing the trick. Even working with the fog parameter I had trouble getting a good result and ended up cheating a bit and adding a falloff map to the refract colour. That allowed me to darken the edges a bit more and gave me a more realistic looking bottle glass.
          Brett Simms
            Someone just pointed out that the material jpg was too small to read - sorry, didn't realize that had happened. Here is a better version:
            http://picasaweb.google.com/lh/photo...eat=directlink
            Brett Simms
              Falloffs are a great artistic addition ot materials in general I think, allows one to pop edges off without having to kill oneself placing bounce cards and lights.
              Two heads are better than one ...
              ....but some head is better than none.....
                True enough, but in this case it was a last act of desperation more than anything else
                b
                Brett Simms
                  thats a crap load of beer. wow (now where is the rum and coke)
                    You should see how many I had in the job images..... It's good for me they were fake.
                    b
                    Brett Simms
                      Seems to be normal beer bottle behavior. The brown seems to multiply to a really dark color. The green ones are a little brighter. Maybe illuminating the surface beneath could give a nice effect and brighten up the bottles.
                        I don't know... I can see what you mean in the examples, but none are really backlit which does change things. The renders do seem close in some ways, but the light just seems to fall off extremely sharply and it doesn't feel natural. None of the people looking at the job I was working on thought it looked right either. These are pro art directors and photographers as well - people who "should" know I guess. Doesn't mean we were right, but it suggest that something was not quite there.
                        I'm running a test with Maxwell to see if my feeling that it works better there is correct. It is never apples to apples, but I can at least see if the light falloff seems more in line with my expectations.
                        Some other photo examples that 'feel' better to me
                        Brett Simms
                          So after rendering another few hundred versions (and one very slow version on Maxwell) I have come back to the conclusion that the problem is just me - surprise, surprise.
                          The Maxwell images are very, very similar in effect. I can't get quite the same lighting (at least not without spending a lot more time than it's worth) but the falloff of light is extremely close - clearly it's just me and my client's expectations being off.
                          I do think there are some more subtle caustic things that happen in Maxwell that maybe aren't happening in the BF GI caustics, or not yet anyway, and that gives some bits of life in the glass that are missing in my Vray renders. Perhaps that is all it is.
                          Thanks for the various inputs anyway!
                          b
                          Brett Simms
                            Are you using caustics in the V-Ray renders? That could probably brighten a bit the bottles
                            • #15
                              are you sure its not that it couldnt be improved with more irregular environment stuff or a white reflector board above / behind / right of camera?
                              (dont want to suggest soemthing you've considered but..)
