I've got 130 render nodes that need to be upgraded to SP3, I don't want to go to each one and install the new update. In the past with other plugins I was able to just copy new files to the nodes and didn't have to go through the install process. Is that possible with this update?
Render node upgrade
A vray deployment system would be better, something like Refamo's node upgrade, but i guess that would have to go in the wish list..
Why don't you just try it on one node to see if it works?
install vray to c:\temp\ and all vray files you need are in the folder
just copy that folder to the nodes - if all nodes have the same path structure run a startup script to copy the files on boot up__________________________________
- moste powerfull Render farm in world -
RebusFarm --> 1450 nodes ! --> 2.900 CPU !! --> 20.000 cores !!!
just 2,9 to 1.2 cent per GHZ hour --> www.rebusfarm.net
I've got a batch file that copies vray files and plugins from a network location and I run it on each machine, although I suppose it would make more sense to make it the other way around - copy them from that location to each machine.
Can you run stuff from backburner? If I could, i'd tell all the nodes to run these bin files whenever server.exe is started.
