Tricky Glass - How ?
LOL
My problem is not creating a cool glass but having the fog like volume AND the totally transparent base part with a different color.
The image you see is a photo and not a render
Thanks3ds Max 2016/2021 (Vray 6.x), Windows 10 64bit , AMD 2990WX ThreadRipper 32/64 Cores, 128 gigs RAM , 2X RTX3090 48GB RAM
download egzglass. i know how the plugin setup up a vray material so i do it manually but egzglass sure is easy to use
if you unwrap the glass (and if you do it with a lathed spline, the unwrapping should be simple) you can use a gradient map to "tint" the refraction of the inner side.
I don't suggest to use different material with different Mat IDs because I think you could have some strange raytrace results.
