Volumetric caustics: fog density is mapped with a Smoke texture
  • Volumetric caustics: fog density is mapped with a Smoke texture
    HI,
    Could we have precision about map you used in http://www.spot3d.com/vray/help/150S...ronmentfog.htm file exemple 5: volumetrics, to have this nice smoke effect with cautics ?
    When i use smoke procedural map in fog density map, caustics disapears....
    could we please have answers Vlado ? or texture file you use for your exemple?
    Thanks and sorry for my english.
    Rudo_fr.
    No answers after severals days ?
    Whaouuu.....
      you can delete this thread.......!
        Did you figure it out? I was trying but did not get it
        Eric Boer
        Dev
          There is nothing tricky about it, it's the same scene, but the fog density has a smoke texture.
            OK thanks for your answers,
            but as i told you, here is my result when i apply smoke procedural texture into fog density slot: it is not like your exemple, as you can see caustics disapears. i have just insert smoke procedural texture in fog density slot, change size to 25 and hit render.
            i'm under max 2009 64 bits.
            Rudo_fr.
              Yep, I get the same thing add a cloud map texture to any of the slots and the caustics go away, I even hacked the subs up to 100 and nothing.
              Eric Boer
              Dev
                It will work if you un-check the "Optimized atmospherics evaluation" option in the V-Ray system rollout. Not quite sure why it does not work with that option on, I have to look into it.
                  Ah good to know
                  Eric Boer
                  Dev
                    Bravo and thanks Vlado,
                    i will check that.
                      Yes your right Vlado, that run well when i unchecked optimized atmospheric evaluation.
                      Cool i can advance in my logo project,
                      Thanks again,
                      Rudo_fr.
