I would make the dome light invisible and then put the hdri into the env slot in the max environment rollout. That way you still have the hdri lighting the scene but not the dome light blocking the alpha....is that what you meant ?
Of course, if you are not using a hdri then just make the dome light invisible and make the background to whatever you want via the max env slot.
