Grass: displacement or vrayfur
  • Grass: displacement or vrayfur
    I've been messing around with displacement for grass recently and am getting some pretty good results thanks to various tips on this forum. I then remembered vrayfur which I have rarely used. Does anybody use this for grass and how do you find it?
    I've done some very limited tests but initially I find it to be a lot slower than displaced grass, but the advantage is that it can bend/taper etc which is quite nice.
    Any thoughts on the matter?
    Kind Regards,
    Richard Birket
    http://www.blinkimage.com
    You never tend to notice the bend/taper unless it's right in the foreground, so you could just use a combination.
    I've been playing around with modeled grass converted to a proxy recently for 'just under the camera' and it works quite well. Not fast, but it was never going to be.
      I also get "better" results for closer seen grass using vrayfur. It does tend to be a little slower at rendering, but it looks so much better. I have been doing some tests using modeled blades combined with vrayproxy and vrayscatter and so far it's outperforming both displacement and vrayfur...
