HowTo improve Animation Rendering
  • HowTo improve Animation Rendering
    Hi there!
    I'm currently working on an animation where animated objects will be included in the final process.
    Yesterday, I rendered aprox. 120 frames of my animation, but got some splotches and render errors back.
    Here's the file for reference...
    http://www.tobyatwork.de/3d-worxx/mo...mera01_new.mov
    The questions, considering improvements for rendering speed and quality, are the following.
    - The animation should be in HD (1280x720 @ 30fps)
    - Does it make sense to render the Irradiance Map @ half resolution?
    - Do I need to turn off AA and reflections / refractions while using the Animation Prepass mode?
    - What kind of settings might fit my scene?
    Since I need to render the animated camera as well as animated objects, I could render the scene frame by frame, with "Add to current map" option or with "Animation Prepass" mode.
    Suggestions and ideas are greatly appreciated
    Thanks in advance,
    toby
    --> http://www.tobyatwork.de
    --> http://www.scriptspot.com/blog/toby
    I assume you haven't shown the moving objects?
    Why not render it in stages - everything that is static (like the reference vid shown) just render from cached IR/LC maps, every thing that will be moving you'll render separately, using BF/LC and then composite them together?
    The splotches and flicker only happen on that one conical object, so first off i'd check that geometry to see you haven't got any co-planar faces...
    P.S. > Show your settings..
      Why should I render with IRR / LC if I render an exterior animation?
      My settings are attached to this post.
        why wouldn't you?
        what were your render times with this setup?
          If textured, about 16min/frame.
