reset glossiness
  • reset glossiness
    Hello,
    is there a easy/fast/script way to reset all the reflection/refraction glossiness of all the materials in a scene to 1.0 ?
    thanks !
    There is a check-box in the "Global switches" rollout to disable all glossy effects in the scene (they will be treated as non-glossy instead).
      yeah i know that one, but the fact is i received a heavy scene from someone that i need to work on, especially on the materials.
      And the guy has set glossy on almost all the materials...and i need to clean this out because rendering at 1h/frame (HD) on dual quad-core, well it is not acceptable for me
        Code:
        theMats = getclassinstances VrayMtl
        for m in theMats do
           m.reflection_glossiness = 1
           m.refraction_glossiness = 1
        this will reset them at the material level.
        The checkbox is a lot better, however, as it'll allow you to go back to the original state with a click.
        Lele
        emanuele.lecchi@chaos.com
        Disclaimer:
          Edit: Well, shouldn't have got a cup of Coffee while writing the message
          If you want it to be really reset within the materials, you can use
          Code:
          for i in (getclassinstances vraymtl) do
                  i.reflection_glossiness = 1.0
                  i.refraction_glossiness = 1.0
          best regards,
          Michael
          This signature is only a temporary solution
            LMAO!
            Well, you're one line short, hence more efficient!
            Coffee worked :P
            Lele
            Disclaimer:
              thanks, you just divided my rendering times by 20
                and if by any chance you know how to script :
                put all the mat ID's to 2 when the material has written "chrome" in its name
                Would be usefull as well for my post-prod
                  Somewhere is a great one called VMC (VrayMaterialControl.) It lets you have control over anything...I believe it was written by Olly?
                    thxs for the info will check this out !
                      Hi Muoto!
                      Instead of answering by private message, i prefer to use your thread, because it might be of interest for others as well, who knows
                      Look at the given code:
                      Code:
                      So what the script does, is to collect all Vray Materials anywhere in the scene (getclassinstances vraymtl), and then goes through all of them to change what you put inbetween the brackets.
                      I quickly listed all the properties of a Vray Material. Now it's up to you to find out how to change the script to make it work. I know you can do it - and to give you a starting hint, boolean means "true" or "false"!
                      Code:
                        .diffuse : RGB color
                        .diffuse_roughness : float
                        .reflection : RGB color
                        .reflection_glossiness : float
                        .hilight_glossiness (reflection_glossiness) : float
                        .reflection_subdivs : integer
                        .reflection_fresnel : boolean
                        .reflection_maxDepth : integer
                        .reflection_exitColor (reflect_exitColor) : RGB color
                        .reflection_useInterpolation (useInterpolation) : boolean
                        .reflection_ior : float
                        .reflection_lockGlossiness : boolean
                        .reflection_lockIOR : boolean
                        .refraction : RGB color
                        .refraction_glossiness : float
                        .refraction_subdivs : integer
                        .refraction_ior : float
                        .refraction_fogColor : RGB color
                        .refraction_fogMult (refraction_fogMultiplier) : float
                        .refraction_fogBias : float
                        .refraction_affectShadows : boolean
                        .refraction_affectAlpha : integer
                        .refraction_maxDepth : integer
                        .refraction_exitColor (refract_exitColor) : RGB color
                        .refraction_useExitColor (refract_useExitColor) : boolean
                        .refraction_useInterpolation : boolean
                        .translucency_on (translucency_type) : integer
                        .translucency_thickness : worldUnits
                        .translucency_scatterCoeff : float
                        .translucency_fbCoeff : float
                        .translucency_multiplier : float
                        .translucency_color (translucent_color) : RGB color
                        .brdf_type : integer
                        .anisotropy (brdf_anisotropy) : float
                        .anisotropy_rotation (brdf_anisotropy_rotation) : float
                        .anisotropy_derivation (brdf_anisotropy_derivation) : integer
                        .anisotropy_axis (brdf_anisotropy_axis) : integer
                        .anisotropy_channel (brdf_anisotropy_channel) : integer
                        .soften (brdf_soften) : float
                        .option_traceDiffuse : boolean
                        .option_traceReflection : boolean
                        .option_traceRefraction : boolean
                        .option_doubleSided : boolean
                        .option_reflectOnBack : boolean
                        .option_useIrradMap : boolean
                        .option_traceDiffuseAndGlossy : integer
                        .option_cutOff : float
                        .preservationMode : integer
                        .option_environment_priority : integer
                        .option_clampTextures : boolean
                        .texmap_diffuse : texturemap
                        .texmap_diffuse_on : boolean
                        .texmap_diffuse_multiplier : float
                        .texmap_reflection : texturemap
                        .texmap_reflection_on : boolean
                        .texmap_reflection_multiplier : float
                        .texmap_refraction : texturemap
                        .texmap_refraction_on : boolean
                        .texmap_refraction_multiplier : float
                        .texmap_bump : texturemap
                        .texmap_bump_on : boolean
                        .texmap_bump_multiplier : float
                        .texmap_reflectionGlossiness : texturemap
                        .texmap_reflectionGlossiness_on : boolean
                        .texmap_reflectionGlossiness_multiplier : float
                        .texmap_refractionGlossiness : texturemap
                        .texmap_refractionGlossiness_on : boolean
                        .texmap_refractionGlossiness_multiplier : float
                        .texmap_refractionIOR (texmap_ior) : texturemap
                        .texmap_refractionIOR_on (texmap_ior_on) : boolean
                        .texmap_refractionIOR_multiplier (texmap_ior_multiplier) : float
                        .texmap_displacement : texturemap
                        .texmap_displacement_on : boolean
                        .texmap_displacement_multiplier : float
                        .texmap_translucent : texturemap
                        .texmap_translucent_on : boolean
                        .texmap_translucent_multiplier : float
                        .texmap_environment : texturemap
                        .texmap_environment_on : boolean
                        .texmap_hilightGlossiness : texturemap
                        .texmap_hilightGlossiness_on : boolean
                        .texmap_hilightGlossiness_multiplier : float
                        .texmap_reflectionIOR : texturemap
                        .texmap_reflectionIOR_on : boolean
                        .texmap_reflectionIOR_multiplier : float
                        .texmap_opacity : texturemap
                        .texmap_opacity_on : boolean
                        .texmap_opacity_multiplier : float
                        .texmap_roughness : texturemap
                        .texmap_roughness_on : boolean
                        .texmap_roughness_multiplier : float
                        .texmap_anisotropy : texturemap
                        .texmap_anisotropy_on : boolean
                        .texmap_anisotropy_multiplier : float
                        .texmap_anisotropy_rotation : texturemap
                        .texmap_anisotropy_rotation_on : boolean
                        .texmap_anisotropy_rotation_multiplier : float
                        .reflect_minRate : integer
                        .reflect_maxRate : integer
                        .reflect_interpSamples : integer
                        .reflect_colorThreshold (reflect_clrThresh) : float
                        .reflect_normalThreshold (reflect_nrmThresh) : float
                        .refract_minRate : integer
                        .refract_maxRate : integer
                        .refract_interpSamples : integer
                        .refract_colorThreshold (refract_clrThresh) : float
                        .refract_normalThreshold (refract_nrmThresh) : float
                      best regards,
                      Michael
                        Thanks !
                        Is this written somewhere in the SDK doc as well ?
                          Do you have the same info for vraylightmtl ?
                            Code:
                            show (vraylightmtl())
                            • #15
                              perfect !
                              learned something new today
