Z-Depth and Transparency- Glass Material
  • Z-Depth and Transparency- Glass Material
    Hello to the VrayForum,
    I am trying to render a z-depth channel but I cannot get the transparency of the glass material.
    There is a house which has large glass facades on 4 sides and behind this windows there are lots of geometry: furniture and trees in the background.
    When I render the z-depth channel, the glass surface nearest to the camera is rendered and everything behind this surface is ignored like glass is not transparent.
    How must I render the z-depth channel so that my glass material is transparent in z-depth too?
    Thanks in advance.
    for my blog and tutorials:
    www.alfasmyrna.com
    there's an affect channels rolldown menu in the vray's mat refraction properties, you specify there where the transparency of the material has effect. set it to colour + alpha and you'll get transparent glass in the alpha channel as well.
      I already tried this but the result didn't change.
      But thank you very much for reply.
      www.alfasmyrna.com
        I'm sorry, I don't know why but I kept reading alpha channel instead of Z. my bad. set it to the third option, which is all channels, then it should work all right.
          Ok
          I will try this. Thanks again.
          www.alfasmyrna.com
