vray and vray rt questions
  • vray and vray rt questions
    Hi
    vray rt looks very promising may remove the need for our studio to use hypershot as much ... couple of questions
    do the various vray sss materials work with vray rt
    will it work with mesh based lights?
    will it work with any kind of micro poly displacement .... or perhaps relief mapping
    on a more general vray question is support for BRDF materials coming and if so will this work with rt
    also is there any kind of curved relief mapping planned for vray?
    thanks in advance for any response
    james
    Last edited by jamesb; 18-05-2009, 05:01 AM. Reason: incorrect material name and a (mistake)
    Not in the initial version.
    Yes.
    will it work with any kind of micro poly displacement....
    Not in the first version, but you can use the 3ds Max displace modifier to work around this.
    on a more general vray question is support for bmrt materials coming and if so will this work with rt
    Not sure what you mean with bmrt materials?
      Hey vlado,
      I've been developing the iso metaballs for VRay, they fill the basic VRayRenderObject (all the same stuff VRaySphere does) etc. so do they automatically work with the RT? Or is there some additional interfaces I need to fill?
      - Jerry
      http://www.ylilammi.com/
        For now we're keeping things to triangle meshes only (and VRayPlane's), since anything else will likely be difficult to support in hardware (if and when that hardware becomes available ). However, when we get to displacement etc it will probably be possible to integrate custom primitives also. In any case, all rendering happens outside of 3ds Max, so you'll need a plugin for the standalone version of V-Ray to make it work.
          Hi sorry i was meaning BRDF materials ...
          shame about no sss as this is one of the main things missing from hyperhot - in order to do organic characters...will support for them come soon or is it non trivial to implement?
          thanks for the very quick response
            BRDFs are not too hard to do; sss is a bit more complicated, but we plan to implement this also.
            If you are interested in trying out our measured BRDF material, you can email me to vlado@chaosgroup.com
              thanks will do
                Vlado, i noticed that the colorCorrect plugin is partially supported (gamma only), i wonder how that works, since it's a 3rd party plugin.
                in any case, color correction is crucial for me (hue/saturation, etc), so i wonder if the new "Color Correction" map included with 3dsmax is supported, and how other procedural 3dsmax maps or wrappers are handled (tiles, noise, gradient, etc).
                Marc Lorenz
                ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___
                www.marclorenz.com
                www.facebook.com/marclorenzvisualization
                  V-Ray RT recognizes it specifically and translates it to a simplified V-Ray implementation. In general, it is possible to implement support for other parameters of the ColorCorrect texture too.
                  The 3ds Max "Color Correction" map is supported, yes.
                  These are supported also, although the results may be slightly different than the 3ds Max implementations (specifically the exact shape of the noise).
                    i'd vote for a dedicated VRaySuperColorCorrect map, with curves (as in the vray FVB), levels, gamma, hdri exposure, optional clamping, hue/saturation, etc.
                    Marc Lorenz
                    www.marclorenz.com
                      does rt support the 'ColourCorrect' plugin by Cuneyt Ozdas now?
                      I know this is a third party plugin, but I also find this to be a crucial plugin in day to day work. Is this supported, or just the 3dsMax 'Color Correction' one that came in Max 2009?
                      (If not, could it be supported - I appreciate it's third party and not guaranteed to be developed in future, but would be a welcome addition )
                        It's definitely an interesting way to go - I spend *way* too much time tweaking materials - but a quick google search did not show much in the way of available resources just yet. Are you aware of many data sets publically available (commercial or free) to start testing a measured BRDF material?
                        b
                        Brett Simms
                        www.heavyartillery.com
                        e: brett@heavyartillery.com
                          Will this support LWF?
                          LunarStudio Architectural Renderings
                          HDRSource HDR & sIBL Libraries
                          Lunarlog - LunarStudio and HDRSource Blog
                            Unfortunately I don't know of any. There is some data collected from various universities, but it does not come in a standard form (there is no standard format that I am aware of). Obtaining such data with sufficient precision is also somewhat of a black art and it is all too easy to get incorrect results in the end (which would make the whole exercise pointless).
                            • #15
                              Thanks Vlado. I'll be curious to see what you guys are doing with measured BRDF then.
                              b
                              Brett Simms
