Select by material
  • Select by material
    I hope this question doesn't make my sound foolish, but can you select all of the elements in a scene with the same material assigned to it? What I have done in the past is create a new material with the same name as an existing. I would then create a dumb object and asign it to that element to override the material. Would this be the correct way to handle this?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
    Why don't you just select objects by material from the object editor ?
    Or maybe I misunderstood your request.
    mekene
      there's a select by material button in the mat editor, is that what you're looking for?
        Select by Material.
        The object selector selects by color, but not material. I'll dig deeper into the material editor. I looked, but didn't see anything so I'll look again.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          In the material editor:
            it's in the right column, second one from the bottom. if memory serves me well..
              In edit poly there is the "select by material ID" option. I use it all the time it works great especially if you provide a name for the sub materials. It took me a long time to figure out what that blank spot was for in the multi-sub menu between the number and the material slot.
