I am working on a scene that needs some objects added into a picture. I created the backdrop image, and a hdri map of the room to match the lighting and reflections.
The table and wall behind it are recreated with 2 simple planes. These have a vraymaterial applied to it. Each material also has a vraymtl wrapper to turn it into a matte material.
I added a vray domelight with the hdri in the texture slot.
Now when I place a glass object on the table, the material of the two planes is refracted through it, which is normal. What's not normal, is that the refracted materials look way too dark.
Here's an image showing what I mean. The materials of wall and table plane are a bit matched to the real colors of the wall and table.
As a test, I turned off the dome light and used the hdri map in the vray environment skylight slot. Now the result is what I would expect:
Here are the two images with the matte option turned off:
Domelight:
GI skylight:
These two all look normal to me.
Any ideas why the domelight darkens the matte materials seen through refractions so much?
Thanks,
wouter
Domelight:
GI skylight:
Thanks,
wouter
