Not sure this is related but I know Discreet will give me crap if I dont ask here too.
VRay 1.09.02a (will do .3a when this project is over, dont have time to deal with all the glossy reflections right now)
Funny thing is I only have a few more frames to get it done.
Sending network jobs that can take quite a while to render (40m average per frame)
Problem is that some of them render and some dont. The monitor shows the error as a time out but when you look at the slave itself on the slave it says
Error: Error deleting c:\program files\discreet\backburner (and so on)\jobname.XML
Why would everything work fine then suddenly most of the slaves choke up this error? I have rendered this same job with no problems for a couple weeks then bammo
here this goes.
There does not appear to be a permissions issue, the folder the XML is in is not read only or anything like that.
I actually watched on of the slaves work on a frame. All the passes completed and it rendered all except 3 buckets or so them the error popped up and then loaded the next job without saving the rendered image which apparently did not finish anyway.
If I render local there is no problem.
Any ideas?
Any ideas?
