Irrad. Map has 0 samples, O bytes
  • Irrad. Map has 0 samples, O bytes
    I have been rendering a simple scene with these settings:
    GI
    First Bounce = Irrad. Map
    Rate -3 to 0
    Secondary Bounce = Direct Computation
    Subdiv. = 1
    Depth = 20
    Adv. Irrad Map
    Mode = Single Frame
    I get a good looking image, however the Irrad Map stats listed in the mode section of Adv. Irrad. Map shows 0 bytes, ) samples ???
    I then get very dark results when I try to use photon map as first or
    second bounce. I ahev checked the "convery to Irrad. map" option in the photon map rollout. No luck. Any suggestions ? Thakns for the great feedback !!!
    I think this is a bug. You have to close and reopen the Render Scene dialog and the Irrandiance map info will update.
    Torgeir Holm | www.netronfilm.com
      Thanks again egz. I'll try this and update with the results. Does this happen in the non-demo version(s) as well ?
