So I did the pre-calc for the irrandiance map using single frame + use camera path. In general it was good except a few areas that are only seen at the beginning of the animation which were very messy apparently due to lack of detail in the IR map.
So I thought I would be clever, un-check 'use camera path' and switch to 'incremental add to current map'. That way I could keep all the work I've already done and simply add to the area that needed more detail by doing a region render on a single frame.
However when I did that it seemed to completely erase the old map since it went from 109mb down to 5.
Is there not a way to add to a map that was done with the 'use camera path' option?
