Maybe some of you already knew, but when a friend told me that ha was able to pause a VRay render I thought he was kidding.
It turns out that if you use Hair and Fur in Geometry mode, the pause button in the render window is enabled during render. If you push it the render stops adding new buckets till it's resumed (even if the object with fur is hidden).
It's pretty useless for most renders, but I thought it would be worth sharing
(Attached a sample scene, MAX 2010, VRay 1.5 SP3a)
