Irr pre-pass with no reflections ?
  • Irr pre-pass with no reflections ?
    Is it possible to carry out the irr pre-pass for animations with no moving objects with the reflections turned off and still end up with the same results. I was just thinking that it would speed up the process...
    Regards
    Steve
    My Portfolio
    Not sure if I made it clear enough. Normally I do an irr pass with reflections/shadows on etc. Just wondering if you can turn off the reflections during an irr pass to reduce the irr pass times ? Will this irr result still lead to the same final render that you would get from keeping reflections on for all objects ?
    Regards
    Steve
    My Portfolio
      Hi Steve,
      As far as I understand it the situation depends on whether you will see a given surface, in your final render, in a reflection or refraction that isn't seen by the camera directly. If you have calculated your irr maps with global reflect/refract off then such a surface will not have receive any gi samples.
      Hope that make sense?
      Cheers,
      Olly
      Set V-Ray class properties en masse with the VMC script
      Follow me for script updates: @ollyspolys
