Storing SSS info for distributed rendering (render farms)?
  • Storing SSS info for distributed rendering (render farms)?
    I want to render one of my scenes using a render farm. (one of the many on the web)
    However, my scene has fastSSS2 materials, which don't come together properly if using distributed rendering.
    Is there a way to store the SSS information, so the scene can be distributed-rendered on these render farms?
    Regards,
    Adam
    VRayFastSSS2 works fine with V-Ray's own distributed rendering, but not if the render farm uses another method to break the image into regions. Saving the sss map has been requested before; hopefully we'll get there.
      DR with SSS will work in the classic way with master and spawner (NOT backburner "split scanline")
      a Renderfarm can not useclassic DR due to some special points
      I not know how other farms do DR - as long they slice the image into parts as I do then DR fail (or better say SSS not fit togehter 100%)
      we at Rebus not simply slice the image into parts - we use a more smarter way so we can render at least LC, IRR and image distributed - you not need to bake the GI first
      but for SSS that way is not working -sadly
      other farm with the classic DR can help you
      __________________________________
      - moste powerfull Render farm in world -
      RebusFarm --> 1450 nodes ! --> 2.900 CPU !! --> 20.000 cores !!!
      just 2,9 to 1.2 cent per GHZ hour --> www.rebusfarm.net
