Best Way to Isolate Objects/Materials After Render
    As for that script dlparisi kindly posted, am I correct in assuming that as you create your scene, it automatically generates a different objID # for each new object you create right?
    But still, with multimatte, you only have 3 solid colors to choose from each time you render one pass?
    Yeah it generates a new obj Id for each object, but it also sets a new Multimatte Element for each ID so you'll get a channel with each object in it.
      Thanks for sharing that script dlparisi! I'm looking forward to the new version.
        Originally posted by jujubee View Post
        I tried multimatte. What I'm understanding is that it will output 3 colors in total and black. So if there are more than 3 items you want to isolate, you would have to do more than one pass?
        you can save out as many as you like with one render - just make sure to rename the channels otherwise youll write them over.
        dlparisi - very cool. and thanks for posting it soon
          I tried multimatte. What I'm understanding is that it will output 3 colors in total and black. So if there are more than 3 items you want to isolate, you would have to do more than one pass?.....
          ..... But still, with multimatte, you only have 3 solid colors to choose from each time you render one pass?
          True, but you can add multiple instances/copies of the Multimatte element to your render elements, and just change the 3 matID numbers (so one has 1,2,3, and the next has 4,5,6, an so on). That way you can have as many as you like and it renders in one pass.
          Brett Simms
          www.heavyartillery.com
          e: brett@heavyartillery.com
            Regarding Multimatte: Why isn't there an option to use the Alpha-channel as well? That way you could use 4 channels per pass...
            • #21
              V-Ray can only store 3-channel render elements at present (even the alpha is stored as a RGB element internally since it is a color really, not just a number), so the multimatte cannot use the alpha.
              • #22
                I've posted the new Multimatte generator script in a new thread at http://www.chaosgroup.com/forums/vbu...nerator-Script
