The VRay version actually looks more like real life glass IMO.
Someone please correct me if I'm wrong...
If you are inside and it's sunny out then you won't get reflections unless the glass is tinted in some way. I think it all has to do with the way our eyes work in real time.
For an example you can see what I'm talking about by holding a black piece of paper up to the back side of a piece of glass and in bright light you will get almost a mirror effect.
Try to use a falloff map on the reflection slot, because with only a vraymap you dont have any fresnel effect, then you should place the Vray map on the white slot.Or you can place the falloff map on the filter color of the vraymap and check fresnel.
But you will allways need to rise the reflection amount to 100 or close.
