Particles and procedurals
  • Particles and procedurals
    I'm doing an animation of an asteroid field. I have some wonderful looking asteroids but I'm running into some big problems because all my materials are procedural.
    Displacement doesn't work in a particle system, so you get around that by using a Mesher object and putting the displacement on that.
    BUT
    Procedurals don't work with the Mesher while things are moving around. You can't even get around it by putting a UVW map set to XYZ to UVW.
    Anyone know if there's a way around this that doesn't involve getting off my lazy ass and taking the trouble to unwrap and bake all my lovely asteroids?
    Thanks!
    - Geoff
    Here is a method I use for distributing vray proxies with pflow. You could do the same with your asteroids with vrayDisplacementMod on them
    http://www.orbaz.com/forum/viewtopic.php?t=1898
    It works well, but its a bit annoying having to bake the particles every time you want to render.
    Jordan Walsh
    Senior FX artist
    Showreel 2010 (new)
    Check out my scripts at Script Spot!
      Thanks. That's a pretty cool tool.
      I ended up solving mt problem by just making tons of copies (600, "hero" asteroids) and I used Neil Blevins' Transform Randomizer to animate them as a group.
      - Geoff
        i recorded a video tutorial on that topic as well for evermotion.org
        http://www.evermotion.org/tutorials/...ow-treeproxies
        hope it helps.
        Anselm von Seherr - Thoss, incendii VFX www.incendii.com
