Is there a VRay Fresnel texture/mask map?
  • Is there a VRay Fresnel texture/mask map?
    I am constructing a custom SSS shader with VRayBlend material, and to get a natural reflection on top of all those layers I want to use a 100% reflective material that is masked by a Fresnel mask that's exactly the same fresnel VRay uses, so that in render elements everything is virtually the same for the custom fresnel reflection and a inbuilt VRayMtl fresnel reflection.
    I vaguely remember reading that VRay does have it's fresnel map available somewhere.
    You can use the Falloff map; it's very similar.
      Alright, thanks. It work's pretty well beside the difference that the raw reflection pass is affected by that falloff. It's not a problem since I won't comp with that. I think it would be great if there was a VRayFresnel map that acted 100% on the render elements internally.
        VRayFresnelmap does not come to VRay3dsMax?
        It is useful in order to be mimic of FresnelCurve based on IOR in VRayMtl.
        OakCorp Japan - Yuji Yamauchi
        oakcorp.net
        v-ray.jp
          In Max, the fallOff map always had the "IoR from shader" mode available.
          The maya version is a nod to that one, i guess.
          Lele
          emanuele.lecchi@chaos.com
          Disclaimer:
            oops
            I forgot IOR mode.
            Thank you very much.
            oakcorp.net
            v-ray.jp
