two bumps
  • two bumps
    Can I add a vrayedgetex and a bump map to the same element's bump slot?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    cant you use comptex to combine them?
    Martin
    http://www.pixelbox.cz
      that makes sense - is it add (a+b)
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        YES! a+b did the job. Thanks for the help!
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          not sure if its the right approach but if it looks nice its OK
          Martin
            what would your approach be?
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              If you're just using the "VRayEdgeTex" to soften edges, "Mix" works well. Just give the edge portion a very low mix amount - even 0.1% will work.
                I use vraycomptex. I also keep the bump multiplier at 30 so that the edgestex work well, and then if you find the bitmap (if that is what you are using for a bump map) is too strong, you can lower the 'bump amount' in the output section of the bitmap
                www.peterguthrie.net
                www.peterguthrie.net/blog/
                www.pg-skies.net/
