Loft and Displacement
  • Loft and Displacement
    I have some walls that I built with lofts and the mapping works great! I can map a nice texture and it wraps all the geometry nicely, but how can I apply a vraydisplacemod if I don't have a UVW map? When I apply a vraydisplacemod to my loft I am not getting my displacement.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Add a UVW Unwrap?
    - Geoff
      that'll screw up the loft mapping coordinate, which makes everything map really nice.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Eh? How can a map be applied to something that doesn't have coordinates?
        - Geoff
          I might have figured it out... I need to apply real world coordinates to the displacement map. I'll get back to you on this.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Adding an unwrap modifier shouldn't change the loft coordinates. It should only make them visible (and editable) in the UVW editor. Or am I missing something?
            Check my blog
              It was just the first thing that popped into my head since I didn't really understand the problem. If you ad an unwrapper, you can at least get a handle on exactly what's going on.
              - Geoff
                AFAIK, displacement doesn't work with real world coordinates, or is this now supported?
                  yes, I forgot that displacement doesn't support real world and the UVW map screws up my lofts coordinates
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    you could try ading UVW unwrap to your base model then add another UVW map and assign it with channel 2 mapping for your displacement.. dont forget to change your displacement map to channel 2 aswell.
                    if you find a bug...kill it.
                      Yes, the UV Map will definitely kill your Loft coordinates, but not the UVW Unwrap.
                      By the way, Ryan's tip about adding UVW channels is good. You can always stack them, which will definitely ensure that your Loft coordinates remain unaffected.
                      Check my blog
                        im confused. whats wrong with loftng and displacement?
                          are you using real worked without UVW maps?
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            not using real world. just standard loft mapping
                            • #15
                              I built stone walls and used a loft, which was wonderful because the stone texture wrapped around all the corners beautifully. I guess I can try without world units... I'll do some testing.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
