HDRI and Bump Maps
  • HDRI and Bump Maps
    Anyone know the best way to keep HDRI lighting from decimating bump
    maps? When my image is rendered without GI turned on the bump map is
    fine (arguably so in the presense of discrete lightsources) but when using
    HDRI map and GI the bump maps are lost..
    I've been able to counter this some by jacking up the reflection samples on
    the VRay Mtl, but I'm at 65 (w/o interpolation) and I'm really starting to
    see a performance hit. Anyone have tips here?
    Thanks!
    escher
    If you dont want use direct lights, (carefull using it might help a lot) u could use some self illuminated plane, which will dirve better the lighting in the scene.
    I think also that your hdri doesnt not have enough high range.
    Maybe a little edit in hdrshop etc.
    finally try to increase the bump map level. Maybe you could find a good balance.
      Why dont you try Vray Displacement mapping works a treat.
      Natty
      Natty
      http://www.rendertime.co.uk
        http://www.chaoticdimension.com/foru...highlight=bump
        this will help you, same question
          Hey
          Many thanks for all the tips, they all were correct and have spawned many more fun hours of trying different things out.
          Escher
