does vray still have troubles with speedtree. i just got it and i had the same error that was reported in june (perhaps there is an internal build that works?).
speedtree works here with the new built. but it´s very slow because of the opacity material. i hope in 1.1 they have an opacity slot in the vray mat. the refration slot doesn´t work that good with speedtree.
but what error do you get ? is it while vray is building the sd tree ? i had that problem once some time ago. the reason was too may trees in the scene. even the scanline had some problems with that scene.
Exactly Marc. Place your opacity map in the refraction map slot. IOR1. Make sure the map has the see-through areas as white (white = 100% refraction / black = 0%).
