Metal renders very speckled
  • Metal renders very speckled
    I have rendered several different metal materials. All of them are rendering extremely speckled. I am looking for a smoother, more dull finish on the metal. Does anyone know what settings can decrease the amount of speckling of the material?
    Reflective glossy samples, most likely.
      I have a light located on the left window to add more natural light entering the space. I have noticed that when I turn this light off, the speckling goes away. When it is on, I have now noticed that all the materials have heavy speckling on them. Any ideas?
        does the light (the one you're turning off and on) have "store with irradiance map" checked? perhaps try that?
          What are your settings in general (material glossy subdivs, AA sampler etc).
            Checking "store with irradance map" worked perfectly. Thanks so much
              Beware that this also reduces detail (shadow etc) to the resolution of the irradiance map. So diving for the actual
              reason (lightsubdivs ?) might be worth it
              Regards,
              Thorsten
                Here is a copy of my settings
                  Have these settings been generated by Solidrocks or something ? If so then most settings cannot be changed as solidrocks will set them to its calculated values if i am not mistaken (from what i read on the forums).
                    Yeah I use Solidrocks. Can I just save the solidrocks settings and exit it, then change whatever is needed?
                      Those look like preview render quality settings with Solidrocks. Are you sure that you set the quality to at least medium for your renders? That would probably explain some of that noise....
                      b
                      Brett Simms
                      www.heavyartillery.com
                      e: brett@heavyartillery.com
