You're quite right in what you're thinking but perhaps by setting the subdivs so high, will it mean that your min aa pass end up using too many rays when you're rendering at aa 1 and taking max material samples? That's one of the reasons that I'd like to know how vray loops between the dmc sampler and the aa sampler up through the levels of quality!
About noise in general
Jérôme,
it's possible divide the subdivs by Refraction/reflection channel?
Now we change all Subdivs
Thanks!
Originally posted by Subburb View PostI'm having a request for guys wich are at ease with maths... :
I'm trying to simplify this tool, allowing the user to enter only 2 values : subdivs for gloss 0.0 and subdivs for gloss 1.0.
All the other values will be computed by the script, in different manners.
for example, the user entered 8 subdivs for gloss=1.0 and 64 subdivs for gloss = 0.0
In linear method, that's quite easy : ((max - min)+1) * glossyvalue or something like that.
in this case, glossy with 0.5 value will have ((64 - 8 ) + 1) * 0.5 = 28 subdivs.
but it would be nice to have also other methods, like log, expo, power, etc.. to compute the intermediate values...
Someone have an interesting formula here ?
Here's the code for anyone who wants to try it:Code:try(destroydialog vrSubs) catch() rollout vrSubs "Set VRay Material Subdivs" ( on vrSubs open do ( vrSubs.theCurve = vrSubs.msa.curves[1] vrSubs.theCurve.color = red vrSubs.subdMax.value = 64 vrSubs.subdMin.value = 8 vrSubs.setCCVal 1 vrSubs.subdMax.value vrSubs.setCCVal 2 vrSubs.subdMin.value ) local theCurve fn getCcPoint curve ptIndex = curve.points[ptIndex] --because getPoint is broken in Max2012 fn setCcPoint curve ptIndex newPoint = (curve.points[ptIndex] = newPoint) --because setPoint is broken in Max2012 fn setCCVal i yVal = ( local pt1 = vrSubs.getCcPoint vrSubs.theCurve i pt1.value = [0,yVal] vrSubs.setCcPoint vrSubs.theCurve i pt1 zoom vrSubs.msa #all ) fn setSpins ccIndex ptIndex = ( local selCurve = vrSubs.msa.curves[ccIndex] local newPt = vrSubs.getCcPoint selCurve ptIndex if ptIndex == 1 do vrSubs.subdMax.value = newPt.value.y if ptIndex == selCurve.numPoints do vrSubs.subdMin.value = newPt.value.y ) fn setVrSubs = ( for vrm in getClassInstances vrayMtl do vrm.reflection_subdivs = getValue vrSubs.theCurve 0 vrm.reflection_glossiness lookup:true for vrm in getClassInstances vrayCarpaintMtl do vrm.subdivs = getValue vrSubs.theCurve 0 vrm.base_glossiness lookup:true for vrm in getClassInstances vrayFlakesMtl do vrm.subdivs = getValue vrSubs.theCurve 0 vrm.flake_glossiness lookup:true for vrm in getClassInstances vrayFastSSS2 do vrm.specular_subdivs = getValue vrSubs.theCurve 0 vrm.specular_glossiness lookup:true ) spinner subdMax "Subdivs @ Glossiness = 0.0:" pos:[10,410] range:[0,128,64] type:#integer fieldwidth:30 --controller:(Bezier_Float()) spinner subdMin "Subdivs @ Glossiness = 1.0:" pos:[210,410] range:[0,128,8] type:#integer fieldwidth:30 --controller:(Bezier_Float()) CurveControl msa pos:[5,5] width:390 height:390 x_range:[0,1] y_range:[0,128] numCurves:1 uiFlags:#(#drawBG, #drawgrid, #ruler, #upperToolbar, #showReset, #constrainY, #xvalue) --#lowerToolbar, commandMode:#move_xy button setVrSubsBut "Set VRayMlt Reflection Subdivs" pos:[5,435] width:390 on msa ptChanged ccI ptI do vrSubs.setSpins ccI ptI on subdMax entered do vrSubs.setCCVal 1 vrSubs.subdMax.value on subdMin entered do vrSubs.setCCVal vrSubs.theCurve.numPoints vrSubs.subdMin.value on setVrSubsBut pressed do setVrSubs() ) CreateDialog vrSubs width: 400 style:#(#style_titlebar, #style_minimizebox, #style_sysmenu)
Dan Brew
wow ! nice approach !
Originally posted by Subburb View Postwow ! nice approach !
If you want to make it more accurate you could make the dialog bigger. Also if you want to position the points exactly there is an optional lower toolbar you can add by adding #lowerToolbar to the array of uiFlags.Dan Brew
Originally posted by lllab View Posthere a small test i made a test with Bertrands Chicago scene,
19min with bruteforce-LC using my method at 1600px, 1h 38h at 5000px wide.
of course it is not fully textured and has no furniture elements,
for the test i put a light gray glossy reflecting material (ior 1.6, intensity 0.5) on all objects, and hdri outside.
brute force, glossy reflection and one hdri dome light, all a subdiv of 256,
AA 1x100x 0.004, DMC all default(threshold 0.01)
colormapping: subpixelmapping on (on makes it dramatically faster for me even though not 100% correct in light then), reinhard 1/0.25/2.2
http://images-stefan.s3.amazonaws.co...BRLC_19min.jpg
i am not sure this says some for fully textured and crowded scenes, but it seems quite ok from noise to me,
AA thrh. at 0.003 would make it more clean of course, render slightly longer
Stefan
I read all what we can read about DMC, noise. etc... The "Stefan method" is good, but if you read well, he wrote: colormapping: subpixelmapping on
with subpixel mapping off, I think with VRay 2.0, with BF+LC (old school or US) it's impossible have good rendering time and no noise (or a few noise). It's impossible (or you have +10 good rendernodes for a single images)
But it's crazy to use 10 rendernode, in the 2012, for a single "normal" image
Again Stefan said: "not 100% correct in light" I reply "yes" only if you don't have glossy, two side material. Otherwise, the differences are very notable (highlight more realistic)
I hope in some "fix" and "development" in the new VRay
We, VRay Users, wrote million thread here and, at the end, no a real solution with sub-pixel mapping ON. Or:
- we have huuuuuuuge rendering time (+50 hours)
- or a lot of noise.
- or, with sub-pixel mapping on, we lose nice highlight
Also, retrace threshold kills the rendering time. In my test x2 time, if you want that this option is slightly visible.
This is my conclusion, after days of test.
New opinions are VERY WELCOME!Last edited by cecofuli; 29-09-2012, 08:43 AM.
Hi Vlado, the good news is that you are researching various options. This means that there is an obvious problem.
And Chaosgroup is working on it. We are waiting for a new samplingGood luck!
i think faster sampling would always be near the top of the to-do list at chaos.. even if everyone was happy with it. i understand people are saying it was faster in earlier builds but ive not noticed any particular slowdown in the later versions myself. having said that i rarely use brute force. we have the lovely imap. with the right settings it can still be pin sharp and faster too. imho, if youre gonna use brute force may as well use maxwell (or rt of course...)
Originally posted by super gnu View Posti understand people are saying it was faster in earlier builds but ive not noticed any particular slowdown in the later versions myself.
VladoI only act like I know everything, Rogers.
Ehehe.. sorry... I wanted say: this means that there is a space for improve the sampling engine
super gnu: VRay is so famous for the flexibility:
I want speed, but a lot of test rendering, splotches (sometime) and human time (change settings etc): IM+LC.
I want quality and "one click" solution with high rendering time: BF+LC
But, as we can see, many people, like me, after seeing the rendering time so high and noisily, we started to think: why not Maxwell or Octane?
This is not the road. I want to use VRay for both solutionsLast edited by cecofuli; 29-09-2012, 09:37 AM.
I have a solution for you: time travel to the futureDmitry Vinnik
Silhouette Images Inc.
ShowReel:
Originally posted by vlado View PostAlso, keep in mind that subpixel mapping ON will *always* be wrong. Our research is directed at less noise with that option disabled.
Also, in the old VRay, if I remember correctly, subpixel mapping was ON by default and unexposed in the UI.
But in my last project (big interior, with a lot of little windows and glossy wood everywhere) with BF+LC With (no universal setting) I had 39 hours at 2500px, with LC retrace on.
With "only" subpixel mapping ON and retrace OFF, now I've 11 hours with I7 920 (and less noise).
Ok, the rendering is less "realistic", a little bit darker, and the highlight less beauty. But the client doesn't see the difference.
But, inside me, I understand that this is no "correct" and I could make better rendering. And I don't like think this.
