Z-value??
  • Z-value??
    If I render with the default scanline with z-value it creates a seperate image afterwards which I can save seperatly.
    How do I do that with Vray?
    The only thing I've seen here when I searched for it is that I can only save the image as *.rpf or *.rla. and not any format that I can open up in Photoshop.
    in viz (maybe max too) you have a rendereffect which let you save a buffer into a seperate file.
    www.cgtechniques.com | http://www.hdrlabs.com - home of hdri knowledge
      That's how you do it with the default scanline render but there's not such a thing in Vray. Well it exist but it doesn't work the same way.
        i guess the only way is to save out the file using the default renderer with passes and batch render.
        Digital Progression
          Ok forgot to tell you. I actually tried scanline first because I know how it works with the Render Elements but here's the big problem. I use Vray Displacement.
            it work, maybe you have forgot to enable z-depth in vray channel selection listbox.
              Work in what way? So it pops up a new window with just the depth map?
